JRSC Reflash cel code!
ep3forlife13
Post by ep3forlife13 »
I just got my ecu back from hondata two days ago and today my car threw a cel code-P0172 Fuel System Too Rich. I have a 2003 civic si with the jrsc reflash. is this typical or is there a problem? thanks
Re: JRSC Reflash cel code!
What is the AF ratio when idling and under boost?
ep3forlife13
i dont have my wideband on hand anymore....i got the reflash since it was properly tuned for my set up...so idk should i get a wideband?
What injectors are you using?
ep3forlife13
RC 440
ep3forlife13
could it be because i have no cat on my car and have a 1 piece race header on it?
That could be part of the problem. I would recommend getting the K-Pro so you can properly tune everything for the modifications that you have.
ep3forlife13
do you know which headers were used for the dyno you guys have posted on the site?
All the information is posted on the website at http://www.hondata.com/reflash_jrsc-si-bigboost.html
I do not have any details other than what is listed there.
ep3forlife13
could it be the o2 sensor going bad that my trigger that?
Have you followed the factory service manual troubleshooting for that error?
