Please Help! My car will not start after update!
cmresh
Post by cmresh »
A couple of days ago I had a CEL come on so I plugged in my laptop to pull the code, which was a P1166. I had updated to kmanager 1.5.1.0, but had not updated my calibaration to that version. I was still using a calibaration from version 1.3.4. So anyway I uploaded the base calibration (K20a-itr.kal) in the new version and now I can't get my car to start. I will upload both the calibration I had been using as well as the one I uploaded which I believe is causing my car not to start. I am just trying to figure out what I need to uncheck or check in order to fix the problem. I was haveing
I do not know what ECU I am using and I do not have the serial number in front of me, I can get them if need be. i am using kpro 1.5.1.0, in a 2002 civic si with a ITR k20a Engine and transmission swap. ARC intake and Toda Race header, Greddy evo2 exhaust. The calibration I downloaded fromt the ECU I saved as "curt old.kal" the one that I uploaded that I believe is causing the problem is "curt current.kal"
Thanks for any help.
Re: Please Help! My car will not start after update!
The 'curt old' calibration is corrupted.
Start with a new calibration (ITR would suit you the best) and check the car starts and run. Then try your most recent calibration which has not been downloaded from the ECU ie it has been loaded from the hard drive.
