Adding boost control to P72 . Want to keep AC and PS switch
JDMCRX
Post by JDMCRX »
Hey guys question
I have a P72 in my car and im also running a AVCR but i would like to use the S300 boost option and use the boost by gear.
Question is.
I have a P72 ecu and i running the WB feed to the ELD terminal. I want to keep my AC and PS switchs on the ecu for the idle up. So i use the PWM A11 terminal witch is ORIG a EGR terminal ?
Re: Adding boost control to P72 . Want to keep AC and PS swi
Remove the AVCR first as it will more than likely just interfere.
Details on boost control can be found at:
http://www.hondata.com/help/smanager/bo ... st+control
