K20a speed limiter?
aznboysrfr
K20a speed limiter?
Post by aznboysrfr »
if I have a jdm k20a with ecu and I reflash it, is the 115 mph speed governor gone??
if not, would it be possible to use a k20a2 ecu and just use the k20a reflash?
Speed limiter
The speed limiter is removed with K20A reflash. It doesn't matter which ECU the reflash goes into.
aznboysrfr
sorry one more question ... is it safe to run straight 91 octane? ... or should I run any octane boosters or 91 with a mix of 100 octane gas? ... can't find any 92+ octane stations around here ... =\
91 octane will be fine
