installed k pro in stock type s, not getting fuel
ef8lsvtec
Post by ef8lsvtec »
im pretty new to k pro but not hondas: im building a kseries crx so i wanted to test my kpro in another car to make sure it was functional. the unit is used it recognizes the device, down loads tunes everything is normal but im not getting power for the fuel pump. the car is bone stock 02 rsx type s, if u put the stock ecu in it.. it runs. if u unplug it and put the kpro on it ... it runs till it runs out of fuel pressure then dies......
is it an imboilizer issue? cant be a pump, cant be wiring, .... must be a setting on my driver for the fuel pump is burned out in the ecu... i only know how to upload maps on it im not a tuner. just want it to run so i can get it tuned
noob to hondata, not hondas
ef8lsvtec
Re: installed k pro in stock type s, not getting fuel
Post by ef8lsvtec »
oh yeah no dtc's displayed on screen, lmk if im missing anything
What is the serial number of the K-Pro and who did you get this from?
ef8lsvtec
Post by ef8lsvtec »
i will get the serial number from it tomarrow at the shop also ill take a pic from the inside, from the inside it didnt seem to be throwing any codes. thanks :)
ef8lsvtec
Post by ef8lsvtec »
sorry its been so long, my son has been very sick andive been having to travel a lot :( so bare with me ... i dont have a photo bucket so ill just type what it says on the inside of the case:
hondata board says: 05002366
the ecu: 37820-prb-A07
2068-701947 0j10
if its just the driver in the ecu im putting it in my 91 crx, so their are other ways of doing that.
again its not throwing any codes but it seems to run till it runs out of fuel pressure becuase the pump isnt comming on and does rev till it runs out of fuel running time about 2-3 seconds thank you for the help
This is a pretty old K-Pro/ECU. More than likely it has been used in a car with an engine swap and faulty wiring, and this has damaged the ECU.
