JRSC+kpro bass map question?
teagie89
Post by teagie89 »
Hi, if i had a type r with the following mods...
JRSC
K-Pro
Spoon b-pipe
Spoon backbox
Gruppe m
RC 650 injectors
Would it be alright to run it on the "european civic type r jrsc 550 inj" bass map?
It would be untill i could get it dyno'd.
The main thing i think would be a problem is the different injector size, and that there isn't a manifold on it, but that wouldn't matter too much i don't think, i don't know!!
Please help and info would be hopefull, Thanks. Teagie
Re: JRSC+kpro bass map question?
No, I wouldn't recommend a European program on a US ECU.
teagie89
Post by teagie89 »
Spunkster wrote:No, I wouldn't recommend a European program on a US ECU.
Its a European car with ECU,
teagie89
Post by teagie89 »
Just been told that the injectors are RC 550 not RC 650. So nothing to worrie about there but would it still be ok to run it on that bass map? Cheers.
Base maps are a startign point. THereis no way for us to say if it will be safe or not. All you can do is try it and make sure the AF ratio is safe and that there is no detonation.
teagie89
Post by teagie89 »
Spunkster wrote:Base maps are a startign point. THereis no way for us to say if it will be safe or not. All you can do is try it and make sure the AF ratio is safe and that there is no detonation.
Ok thanks, it would only be for a short time jst untill i can get onto the dyno. Thanks for the help.
