Knock sensor?
burmese434
Knock sensor?
Post by burmese434 »
Going to install a knock sensor and was wondering if I need a special one? Also I know you don't want any knock but is some ok?
Re: Knock sensor?
What ECU are you using?
burmese434
Re: Knock sensor?
it's a p75 with vtec added
Re: Knock sensor?
That ECU does not support knock control. Installing a knock sensor will do nothing.
burmese434
Re: Knock sensor?
Man that sucks. I thought it did because if I don't disable it, it will throw a code? So what do I need to do to get one setup in my 96 cx hatch?
Re: Knock sensor?
You must use an ECU that has the circuitry for knock control (P30, P72 or P61).
Dr.Auto
Re: Knock sensor?
Post by Dr.Auto »
Spunkster wrote:You must use an ECU that has the circuitry for knock control (P30, P72 or P61).
So P28 does not have circuitry for a knock sensor? If not this answers my question for why i keep setting a knock sensor code for my P28.
Is it possible to solder in the circuitry for knock control much like for the vtec control?
Re: Knock sensor?
There is a list of OBD1 ECUs and what they support at http://www.hondata.com/ecus.html
No, you cannot add the circuitry needed, you must get a compatible ECU.
lowblow
Re: Knock sensor?
Post by lowblow »
What is the Knock sensor use for on P72 ecu?
Re: Knock sensor?
detecting knock and retarding the timing
lowblow
Re: Knock sensor?
Post by lowblow »
Best for NA or Turbo?
