Using preloaded map but modifying secondary 02
xplizitremix
Post by xplizitremix »
I want to run a Toda map on my Flashpro but I want to eliminate the secondary 02 sensor so i can remove it completely from my exhaust system.
Can anyone guide me through the steps to do that?
I have an 06 + S2000
Looking to run the Toda reflash but just eliminating secondary 02 sensor as I find its useless on my J's Racing 70RR exhaust
Re: Using preloaded map but modifying secondary 02
In the calibration under closed loop, just disable the secondary o2 sensor and upload the calibration.
xplizitremix
^ Thanks for the reply
So i would have to open the toda map first, then in calibrations disable it then save it first? or do i just load what i just modified ontop flashpro and i Should be good to go?
I thought i did this the first time but my car threw a CEL after i removed my secondary 02 sensor from the car. (Disconnected it completely from the plug)
If you are having a problem you must post the calibration and a datalog showing the problem as well as a detailed description of the problem. Also a list of what has been done to the car.
