Turbo B16A
ej1serge
Turbo B16A
Post by ej1serge »
whats up guys, i wanted to see if anyone can help me get setup with my new s300 unit, i wanna be able to at least get the car to drive from my house to my tuners shop which is about an hour and a half drive, i just need something to get my car to run pretty decent with light throttle and to be able to hold idle pretty good lol
my setup consists of
B16A Stock Bore Stock Stroke
JE 9.8:1 Pistons/Eagle Rods
Injector Dynamics 1000cc
GM 3Bar Map
VictorX Manifold
70mm Throttle Body
Ericks Racing/Alaniz Ported B16 Head
RLD Fab Ramhorn Manifold and 3" exhaust
Garrett T3T4 60 Trim Turbocharger
Tial 38mm @ 16 psi
Full-Race Backdoor Intercooler w/ TiAL Q
2.75" Cold Side Chargepipe
any more info needed please let me know i will respond as quickly as i can, thanks in advance to anyone who can help me out!
ej1serge
Re: Turbo B16A
Post by ej1serge »
anyone ?
Progress
Re: Turbo B16A
Post by Progress »
do you have a wideband
tuning upon request
347-989-5028
9.23@167 B18C street/track tuned
HP unknown
ej1serge
Re: Turbo B16A
Post by ej1serge »
yes i do i have a aem wideband, i got it to idle and everything i drove it up and down the street its running a bit rich so id just have to adjust that, it will start fine and take off cool but maybe like 20-30 secs into the drive it seems like the sparkplugs get wet and it starts misfiring, wideband shows like 10.7
Progress
Re: Turbo B16A
Post by Progress »
Run the white wire from the wideband into s300 d10 pin
tuning upon request
347-989-5028
HP unknown
ej1serge
Re: Turbo B16A
Post by ej1serge »
i have that set up as well, im trying to figure out wether i need to calibrate the voltage offset or not, ive searched and searched and came up with alot of mixed answers
Re: Turbo B16A
Yes you need to set the voltage offset.
ej1serge
Re: Turbo B16A
Post by ej1serge »
is it different for every car or is there a certain voltage offset for the AEM wideband?
Re: Turbo B16A
Every car will be different, try different voltages until you get the readings on the gauge to match the datalogged readings.
ej1serge
Re: Turbo B16A
Post by ej1serge »
thanks!
