ignition
danno
ignition
Post by danno »
Have searched already but didn't find anything specific
What can cause kpro to not see the ignition turn on?
Re: ignition
It is usually a wiring problem or a damaged ECU from a wiring problem. Try the ECU in a known good vehicle.
danno
Re: ignition
Post by danno »
I will try that tonight and repost
Can I have a ecu sent in and repaired?
danno
Re: ignition
Post by danno »
ecu works fine, are there any certain wires or particular relays to check? ive checked all the fuses under hood and dash
vehicle is 2005 civic si, had kprod back in 06
oem harness but dash was removed and non necessary items removed heat etc.
Re: ignition
Look at the wiring you have changed, something has been done incorrectly.
