Force radiator fan on parameter not working?
Mirage22
Post by Mirage22 »
Ok so I have had my kpro for about 3 years now and just now am wanting to setup the force fan on at parameter to somewhere around 185-190 deg area the only problem is it didn't work when I changed it in my calibration... So I thought maybe it wasn't wired in or whatever since I used Hybrid racing kswap harness I found this weird so after doing some schematic research I then tested B6 pin on the ecu connector by grounding it out and the fan turned on so that tells me the wiring is good. I then thought maybe one of the ecu grounds were not strong enough to turn fan on so I tested all of those and they had no issue what so ever. I am now thinking its a possible driver issue in the ecu or something im just overlooking so if anyone knowledgeable would like to take a stab at this and help me figure it out I would greatly appreciate it. Its a '94 civic cx hatch with a '03 k20a2 using the hybrid-racing conversion harness.
PLAYTIME PERFORMANCE
'94 Civic CX Hatch
K-Swapped
I/H/E untuned
12.85 @ 104mph
D2B2K
Build Thread
Re: Force radiator fan on parameter not working?
Are you using a relay?
impc
Post by impc »
also force radiator fan did not work on Euro Civic Type-R (EP3) using PRB KPro ECU
