2 step switch.
civicturbo1976
2 step switch.
Post by civicturbo1976 »
hi. this answer has probley been answered before. im trying to install the switches that i need clutch switch ect to use 2 step on my s300. can any one help as to what i will need to do for this.
Re: 2 step switch.
HAve you read the help file for Full throttle shift and launch control?
http://www.hondata.com/help/smanager/la ... ch+control
http://www.hondata.com/help/smanager/fu ... ttle+shift
civicturbo1976
Re: 2 step switch.
i looked at your link but what im looking for is info on pedal switch .as im running no inside loom im gona have to wire up a clutch switch to disable 2 step arnt i. this is all new to me.:(
Re: 2 step switch.
You will have to wire in a switch activated by the pedal to one of the inputs selected in the software. You will have to determin if the input you choose is a pwered input or a grounded input and wire it accordingly. IF you are unsure about how to do this, you should contact the nearest Hondata dealer to assist you with this wiring. Incorrect wiring could damage the ECU.
