Punching Out the USB Hole
7rrivera7
Post by 7rrivera7 »
I've been installing several S300's lately and I'm spending too much time punching out the hole with a Dremel (I'm anal about how it looks). Is there anternative/shortcut/better method of preparing the ECU case?
Re: Punching Out the USB Hole
Make two vertical cuts with a hacksaw. Break off the tab with pliers. Smooth with file.
BTW this is not how we do it here - we have a milling machine.
locash
Post by locash »
If you have access to a drill press, you can use an end mill..
Something like this will make a nice flat bottom..
http://www.amazon.com/dp/B003BIEUZY/ref ... B003BIEUZY
Locash Racing, LLC
Hondata Sales and Tuning
Dynapack 4000 2wd Dyno
In-Shop CNC Machining and Product Manufacturing
