FlashProManager V1.1.9.6 (beta)
V1.1.9.0 changes:
  • FlashPro firmware updated to version 35
  • Improved datalogging/recording performance when display window is maximized.
  • Fixed adjustment function on Lambda values using AF ratio units.
  • Fixed tabs in the settings window.
  • Added automatic refresh option to OBDII diagnostics window.
  • Added a clear display option to the display window.
  • Added delete and backspace key functionality to the display window.
  • Changed Increase/Decrease in AFM fuel tables to a percentage change.
  • Added automatic conversions to sensor display minimum and maximums, and also sensor warning minimums and maximums.
  • Added functionality to saving window position for multiple monitors.
  • Included security check to prevent saving data to Program Files to avoid virtualization problems with Windows.
  • Added Import/Export feature to the Sensor Settings form, the Graph Template form, and main Settings form.
  • Fixed bug where exception is thrown when sensor display min and max are the same value.
  • Added a driver check entry to the status bar, a balloon hint to install the driver, and a check box to disable the balloon hint.
  • Added 2D graphs to the small tables in the calibration form.
  • Added the ability to alter the short term fuel trim minimum and maximum under closed loop in the calibration form.
  • Added a compare calibrations option to the main menu under file.
  • Modified the exception report form to directly email reports to Hondata instead of populating users email service.
  • [Civic CTR - Euro] Added option to enable and disable ignition IAT retard to ignition knock limit and to ignition advance.
  • [S2000 - Euro] Added option to disable air pump. If enabling boost control, then disable the air pump to avoid any DTCs.
  • [S2000 - Euro] Fixed P1412 DTC.
  • [S2000] Fixed gear ignition compensation table.
V1.1.9.1 changes:
  • FlashPro firmware updated to version 36
V1.1.9.2 changes:
  • FlashPro firmware updated to version 37
  • [Civic Si] Fixed EPS and ABS error codes after upload
  • Fixed rounding in fuel flow setting
  • Fixed lambda double click changing units
  • Changed datalog comment time to use regional settings
  • Changed datalog export to use regional settings
  • Fixed copy and paste unit difference in some tables
V1.1.9.3 changes:
  • Civic Si - Race] Added fuel economy parameters.
V1.1.9.4 changes:
  • Added grouping and right justification to the Sensor Window.
  • Added autotune function.
  • Add tool tip window to lambda and fuel overlay.
  • [Civic CTR - Euro] Added MAP based fuel table option.
V1.1.9.5 changes:
  • Fixed lambda overlay tool tip window sizing.
  • Display lambda overlay tool tip window when viewing suggested fuel change.
  • Added overrun fuel cutoff delay table.
  • [Civic CTR - Euro] Manage fuel table display based on speed/density fuel table selection.
V1.1.9.6 changes:
  • Changed default lambda overlay throttle & load settings.
  • Fixed datalogs not compressing.
See this post for more information about the changes made in V1.1.9.4.
soxfan143
Re: FlashProManager V1.1.9.0 (beta)
Post by soxfan143 »
Derek, This Beta has major bugs!! I sent you an email as well but I figured I'd post this just in case. Here's the issue. I updated last night and tried flashing the ECU and when I did the program button was totally unresponsive as was the datalog button once I got the flash to take. Also when the flash was complete the ECT gauge did not illuminate afterward and the MIL turned on with U0122 and U0155 (I think) which are FCAN communication failures.
Edit: Never mind. I got your email a minute ago. Thanks Derek!!
Re: FlashProManager V1.1.9.1 (beta)
We've fixed the datalog and program buttons not working. I don't get the same error codes after an upload, but will continue testing.
soxfan143
Post by soxfan143 »
The buttons are fixed but I'm still getting the Coolant gauge malfunction along with the MIL with those 2 codes. U012s is VSA to ECU communication failure and U0155 is ECU to gauges malfunction. Both are FCAN failures which is CAN BUS com failure. I only get it after a reflash and for some reason the ECT gauge is staying out until I key off the car and key it back on but the codes are hard codes and will not reset unless I physically clear them with either FP or my MODUS scanner.
skier
Post by skier »
same as me,
i'm getting the same 2 errors as you soxfan.
and like you, i must reset them using the DTC clear function..
I got these 2 errors even after a return to stock is done..
worse still, once the software upgrade the firmware to the latest,
it can't be downgrade to the firmware used in 1.1.8.5.
Argh...
ModFreak
Post by ModFreak »
Same here, my ride is a JDM FD2R and I'm getting a U0155 code.
VitViper
Post by VitViper »
Hey Derek, we have yet another car doing the same thing. U0155... Was fine on 1.1.8.5, and going to 1.1.9.1 broke his gauges, they don't work at all now. Error code in attached log...
Sucks, this is quite troublesome....
Maybe I should email you about this... but what would it take to get the gear selector working correctly in FlashPro when the gearing and final drive gets changed? Do you need a car to test on look at? My car is nearing completion, and the gearing is radically different from stock... I have done a few other cars with modified gearing, and there have been requests on properly working BBG and gear based comps. I had to do a 97% speedo correction for one guy with the 4.1 final drive and PPG 3/4 gearset....
Re: FlashProManager V1.1.9.2 (beta)
V1.1.9.2 should fix your problems. I never got any error codes, but did get an EPS indicator until I switched the ignition off again.
soxfan143
Post by soxfan143 »
yup it's all fixed!! Thanks Derek!!
mucter
Post by mucter »
Derek, love the new features in FPM. Been waiting patiently for those 2d graphs, they will be a huge help. A couple notes
1) when they make the calibration window have a scroll bar, the scroll wheel on the mouse doesn't appear to work to scroll the window down. It only scrolls the left part of the window. It's as if you're not allowing the right part of the window to take focus and thus inherit the command to scroll sent from the mouse.
2) any chance we'll be able to use the 2d graphs for editing? Click / drag like the main tables?
3) Under Calibration -> Throttle, it looks like Target Throttle Plate got renamed to TPlate Normal.... unless this is an indication that you're going to reveal more throttle plate functionality ;-)
skier
Post by skier »
Yeah man,
problem fixed.
1. The compiler I use doesn't support the mouse scroll wheel. Native windows components scroll but other controls do not.
2. I was wondering how long it would take for someone to ask that... possibly in the future.
3. For vehicles which have more than one throttle map.
mucter
Post by mucter »
Hondata wrote:1. The compiler I use doesn't support the mouse scroll wheel. Native windows components scroll but other controls do not. - Bummer
2. I was wondering how long it would take for someone to ask that... possibly in the future. - Not a huge deal, just thought I'd see.
3. For vehicles which have more than one throttle map. - Word
FN2 Civic Type R users - please try the race calibration to see if the fuel economy gauge works.
Thanks.
sc0rcher
Post by sc0rcher »
Hondata wrote:FN2 Civic Type R users - please try the race calibration to see if the fuel economy gauge works.
Thanks.
Hi, is it 1.1.9.3? Noticed the new update, wondering wat is the diff from 1.1.9.2...
