tps reading -1%
miaep3
tps reading -1%
Post by miaep3 »
i installed a new tps sensor ktuned. re-calibrated the tps. Now my tps reads negative 1 when the throttle is closed.
i installed my kpro on another car tps read 0% when throttle is closed. i re-calibrated the tps then it also started to read negative 1%. what could be causing this.
Thanks.
miaep3
Re: tps reading -1%
Post by miaep3 »
here is a screen shot
impc
Re: tps reading -1%
Post by impc »
my TPS started reading -1% when upgraded to 1.5.1 (stock TPS sensor), recalibration does not work.
miaep3
Re: tps reading -1%
Post by miaep3 »
impc wrote:my TPS started reading -1% when upgraded to 1.5.1 (stock TPS sensor), recalibration does not work.
same thing happen to me
i installed it on a stock motor with stock tps sensor and still read -1 when i re-calibrated it.
don_killah
Re: tps reading -1%
Post by don_killah »
Yep, It happened to me too. Something is up with the new kmanager software.
impc
Re: tps reading -1%
Post by impc »
if i enter values manually (minimum reading), i can get values to display 0, but engine in some situations does not "understand", that i'm off throttle (probably reading wrong TPS value),
and idle is acting strange (rpm ~1200 and cam. angle surges from 0 to 20)
Zoro2006
Re: tps reading -1%
Post by Zoro2006 »
1.5.1 has some more bugs :(
Known as Vaikis_
mkulak
Re: tps reading -1%
Post by mkulak »
miaep3 wrote:here is a screen shot
Make your minimum throttle 10.5 and it should read zero. Whenever I see -1% I add .5 to the minimum number and it is fixed.
Need a Kpro or s300 Tuned in the Toronto area? Send me a PM.
miaep3
Re: tps reading -1%
Post by miaep3 »
okay ill try that.
And yeah there are a few bugs also cause for some reason the idle is also not wanting to stay where it should be.
miaep3
Re: tps reading -1%
Post by miaep3 »
okay ill try that.
i tried it and nothing still reads -1
Zoro2006
Re: tps reading -1%
Post by Zoro2006 »
try to install new KManager http://hondata.com/updates/KManagerV3-0-0.exe
Known as Vaikis_
miaep3
Re: tps reading -1%
Post by miaep3 »
so the new kmanager works with my kpro or its only for the new kpro?
Re: tps reading -1%
It is for all K-Pros.
miaep3
Re: tps reading -1%
Post by miaep3 »
Spunkster wrote:It is for all K-Pros.
still reads -1 with the new Kmanager
tiger
Re: tps reading -1%
Post by tiger »
Indeed. I can confirm this as well.
