Fueling on Overrun (for piston/valve cooling)
Dan1987
Post by Dan1987 »
Is it possible to configure the overrun cutoff and recover parameters in flashpro so that we can continue to inject fuel on overrun? May be usefull for piston/valve cooling during very agressive running etc.
Dan (EDM S2000)
Re: Fueling on Overrun (for piston/valve cooling)
Adding overrun fuel will wash down the bore so that the ring seal will go away. The engine has oil jets for piston cooling.
