Smanager can't connect using windows XP
dneil_27
Post by dneil_27 »
Hi to all, i download the smanager at hondata web,but i can't connect to the main unit. It will shown" ur new hardware might not working properly .Why?.Last time i'm used windows vista for my smanager, everythings is ok. I also tried to update the driver , uninstall the software and reinstall again and again but still can't connect.. please help me!!
Re: Smanager can't connect using windows XP
What does it show up as in the Windows device manager?
dneil_27
Post by dneil_27 »
Spunkster wrote:What does it show up as in the Windows device manager?
I open the divice manager and click the usb, it shown (!)(yellow) at the hondata usb divice.Then right click and update the driver but, still can't connect.
What directory are you pointing it to to install the driver from?
dneil_27
Post by dneil_27 »
Spunkster wrote:What directory are you pointing it to to install the driver from?
Same like usually i had install before, download the smanager software, run the ecu editor setup wizard, accept license agreement, select destination location,select start menu folder,select additional task then install. That's all should i done right?
What is the name of directory which you are installing drivers from?
dneil_27
Post by dneil_27 »
Hondata wrote:What is the name of directory which you are installing drivers from?
S300 V1.5.4.0 u means this?
Open your Windows device manager, find where the s300 is showing up there and right click and select update driver and follow the instructions below.
http://www.hondata.com/help/smanager/ma ... lation.htm
dneil_27
Post by dneil_27 »
Spunkster wrote:Open your Windows device manager, find where the s300 is showing up there and right click and select update driver and follow the instructions below.
ok. i got it, problem slove. thank's soo much..
