Has anyone made a good H22a map? Ever? Why's it so illusive?
tb144050
Post by tb144050 »
Everyone says not to use the included H22 maps because they have crazy ign/fuel/lean/rich problems :(
Everyone also says to use the p72 and do this, do that..which is what I am trying...and failing at. I am running way to rich in closed loop (10's) and then in open loop it goes straight to max lean (17.77) using my stock narrow sensor.
I just want to see a map that is already tuned to run 14.7 lambda on a h22a1 N/A. Not too much to ask, is it? I am still going to try to finish my own map, but I want to see the curves/lines of a known-good h22a map before I blow up my motor following vague advice.
Pleeeeeeaaassseee and thank youuuuu verry verrryy much in advance,
--TJ
hpmx18
Re: Has anyone made a good H22a map? Ever? Why's it so illus
Post by hpmx18 »
i can post 1 i did a few months ago for a jdm h22 bone stock in a couple hours
LGMotoring
IG:Lgmotoring_official
Lgmotoring.com
tb144050
Post by tb144050 »
Can you tell me more about this tune? From the notes (Stock JDM P72 (92-95 B18C Integra)), I can guess u used the b18c as your base and tuned it up to make it work.
Was this a dyno tune? Street tuned with a WB AF gauge?
Yes, i am a noob. I bet you were a noob once upon a time. lol
hpmx18
Post by hpmx18 »
tb144050 wrote:Can you tell me more about this tune? From the notes (Stock JDM P72 (92-95 B18C Integra)), I can guess u used the b18c as your base and tuned it up to make it work.
street tuned with aem(inline)wideband
LGMotoring
Lgmotoring.com
tb144050
Post by tb144050 »
I never got a chance to try out your tune before I spun a bearing and started a rebuild with f22 crank/rods....anyway, I was hoping you can tell me how well your tune performed under daily street use and/or high throttle conditions?? Just anything you remember about its performance?
keto06
Post by keto06 »
buy a wideband, wire into Hondata, and post the logs.
02 RSX Type S (sold)
11 TSX Tech (daily)
Hit me up for free Hondata Help. Over 4K downloads on my famous GSR Tune!
tb144050
Post by tb144050 »
keto06 wrote:buy a wideband, wire into Hondata, and post the logs.
already got one wired.. gonna be about a month before I get it ready to crank again :(
keto06
Post by keto06 »
that h22 map posted above is fine for a basemap. Just get to logging!
11 TSX Tech (daily)
