reflash to kpro
mat_660
reflash to kpro
Post by mat_660 »
hi
I want some information about upgrading my reflash to kpro.
Honda civic SI 2004 EP3
37820-PNF-A05
031049-3312
Kehin europe LTD Made in UK
It is sell before the price drop but I'm not the first owner.
thanks
Re: reflash to kpro
There is no record of this ECU being reflashed.
mat_660
Re: reflash to kpro
Post by mat_660 »
I'm sure it is reflashed. the rev limit is 7800 rpm. ONLY hondata can modify a k series computer right ???
You can't see something on the ecu for confirm you it is reflashed ???
The ecu was reflashed in 2008. It do some years !!!
http://www.imagup.com/pics/1284654613.html
help me please
Re: reflash to kpro
We have not reflashed this ECU. If you have the dealer who you went through and a date we can check again.
The stock usually reads over by 200-300 rpm at redline, so that using it to determine the rev limiter may not be accurate.
mat_660
Re: reflash to kpro
Post by mat_660 »
Before with the stock ecu the rev limiter occur at 7100 rpm. (on the tach)
Now with this ecu the rpm go at about 7800
I'm happy of the reflash but I want swap
For the date and dealer I don't know.But I came from Quebec in canada if it can help.
And it's in 2008.
You can't see something on the ecu for prove it.
Re: reflash to kpro
Yes, it does sound like a higher rev limit. There is nothing we put on the ECU, but do record every serial number that we reflash. A dealer and date would be a great help.
mat_660
Re: reflash to kpro
Post by mat_660 »
hi after some check on my ecu I have find the number on the ecu box and on the electronic are not the same
SO The number on box : 37820-pnf-a05
031049-3312
and on the plug: 37820-pnf-a05
031049-3308
check the pic you see the plug and box number
http://www.imagup.com/pics/1284654469.html (box)
http://www.imagup.com/pics/1284654613.html (plug)
Let me know
thanks
Re: reflash to kpro
THere is no record of this ECU being reflashed by us using either of the numbers you provided.
