Wideband adjustments???
Manny1987
Post by Manny1987 »
Ive been trying to set-up my friends PLX wideband but havent been able to dial it in. What have you all used in the Voltage offset and the Conversion table? I have him running around in Open Loop right now until I can get it dialed in any helps is appreciated.
Re: Wideband adjustments???
YOu can only set the offset by getting the datalogged value to match what the wideband display reads.
