89 Crx dx
Lmackey
89 Crx dx
Post by Lmackey »
I have a 89 Crx dx with a d15b7 and Pm5 ecu, from what I've read so far is that the s300 will not work with my ecu. What do I need to be able to make this work, a different ecu and adapter for the harness? I've looked around the site and can't seem to find what I'm looking for.
I would like to turbo charge the car in the near future and I heard that the easiest way is with Hondata.
Re: 89 Crx dx
You will have to convert to OBD1, and use an OBD1 distributor. I do not know if there is an OBD1 distributor that bolts up to that engine properly. To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html . You can then use the Hondata s100 or s300 depending on what options you want ( http://www.hondata.com/sproducts.html ). I would recommend the s300.
