can I only use the Hondata USB serial ??
dadon1
Post by dadon1 »
Will the S200 only communicate with Hondata USB serial cable or can I buy one at radio shack?? If so which brand will work?
dadon1
Re: can I only use the Hondata USB serial ??
Post by dadon1 »
Any info please
What exactly are you trying to do? What is the serial number of the s200?
dadon1
Post by dadon1 »
Spunkster wrote:What exactly are you trying to do? What is the serial number of the s200?
basically data log and anything else i can do on my laptop while connected
dadon1
Post by dadon1 »
so there is no usb serial i can buy other then Hondatas usb.. to datalog??
you have not said what the serial number was
RofromNorCal
Post by RofromNorCal »
i have the same problem
Im guessing the Ser. Num. is on the back of the unit
so my should be this
s200-4862
RofromNorCal
I want to tune... just play with the system see
if i canmake some power
do real time datalog
and so on
You cannot make any changes by datalogging. If you want to make changes you should upgrade to the s300. The only other way to make changes is to take the car to one of our deaelrs and have them retune it on the dyno.
Details on upgrading can be found at http://www.hondata.com/s300upgradeform.html
tomzauto
Post by tomzauto »
can you datalog and tune without the hondata cable ?
i have an s200 with an ostrich emulator, chip burner & i want to use RE4
can i get a cable at radio shack because i bought the s200 used and the seller did not have the cable
No you cannot. You would be much better off selling some of the parts and upgrading the s200 to an s300. It is much easier to use and has more features.
