help with engine bucking
articsilber323
Post by articsilber323 »
hi i have a h22 all motor street car
stock bottom end with built head with skunk2 pro 1 cams
everything on the intake manifold has been blocked off except vacuum for fpr and iat sensor
the car has a terrible bucking problem with starting to drive aka taking off from a red light
the car violently jerks back and forth it only does it like 0-3% throttle and is very hard for it not to do
have you experienced this before and do you know a fix?
i have tried 3 different throttle bodys 1 being stock that worked fine on another car
2 tps
2 map sensors
tested for vacuum leaks
any help would be appreciated thank you
i have attacted a data long when it is bucking
also the calibration
cloviskilla
Re: help with engine bucking
Post by cloviskilla »
with a voltmeter probe the middle wire on tps with it plugged in with key on engine off. set it to 0.5 volts idle and 4.5 volts wot. then upload this map. should fix it.
articsilber323
tps has been set at .5v idle and 4.5 wot and then calibrated in s300 for min and max
can i ask what you changed?
cloviskilla
articsilber323 wrote:tps has been set at .5v idle and 4.5 wot and then calibrated in s300 for min and max
Well according to your posted map the tps wasnt set to stock specs or calibrated right?? I smooth timing tables and set tps overun and put min and max to stock .5 to 4.5
articsilber323
still doing it with the new map and adjusted tps
here are two logs
Have you calibrated the TPS in the software?
http://www.hondata.com/help/smanager/tp ... =tps+range
articsilber323
yup thats what i was doing before
