kpro problem
hondak20
kpro problem
Post by hondak20 »
Hello
KPro serial number: 05004866
37820-PRB-A05 ECU
k20a2 engine N \ A
K-manager 3.0.3
Stock injectors \ 63mm exhaust \ intake filter \ DC5 cams \ intake manifolds PRC
swap honda civic EC9
all right so far.
k-manager version 1.5 gave me problems to 5500rpm limiter
tps -1%
the problem started when I was loading the mapping.
loading the mapping and is stuck in the middle, unfortunately the PC and downloaded and then switched off.
when I turned on I tried to reload the map, unfortunately
I do not enable the loading of the map \ lightning \ erase ECU etc..
can only qualify me for the encounter snow-KPro-information. nothing more ...
If I insert the USB KPro, the car lights \ AFR 10,6:1 \ engine light comes on .. KPro and the lights are solid green \ red light flashing
If you do not insert the USB, the drive turns on without any error. Engine light is turned off ..
solid green \ red light off.
can you help me?
the problem and the KPro or the PC?
pingpong
Re: kpro problem
Post by pingpong »
when i used k manager version 3.0.3 my car wouldn't start, so i've uploaded a map using version 1.5.1 but got stuck with a 5500 rev limiter as well.
As of yesterday i have had the same issue. my pc is detecting that the krpo is connected but it wont communicate.
i've tried uninstalling kmanager and usb drivers, ive tried reinstalling differnt version of kmanager and also usb drivers.
nothing seems to work.
luckily my kpro still has the map i uploaded from version 1.5.1, my car still drives with a 5500 rev limiter
could this be a BUG in the new kmanager software ? or a dead kpro..
hondak20
Re: kpro problem
Post by hondak20 »
I hope to get some response from Hondata ..
Re: kpro problem
Please follow the posting guidelines.
hondak20
Re: kpro problem
Post by hondak20 »
Hondata wrote:Please follow the posting guidelines.
Where can I find these guides lines?
rilsolvere you can explain to me how this problem?
I can not do anything at the end, I can not clean the map, I can not upload \ or take a datalog. , The boxes are disabled.
Clean_EH2
Re: kpro problem
Post by Clean_EH2 »
Yea, i'd like to know where to find these posting guidelines?
Also, I hope hondata is just as concerned with the problems their customers are bringing to their attention just as much as following the posting guidelines : ) [thinking out loud]
Re: kpro problem
The posting guildlines are found under Before posting in this forum read this
If you want to help us solve the problem then provide the information rather than trolling.
hondak20
Re: kpro problem
Post by hondak20 »
a datalog, I can not do because it is completely blocked.
I can not record data \ view \ and I can clean and refresh the mapping ..
In fact I say that as soon as I installed the 3.0.3 kmanager I had this problem.
KPro number: 05004866 ..
the other data I've already written ..
As I said, and a swap honda civic .. EC9
I followed your wiring diagram, so good, no errors.
then the problem started when I updated the version 3.0.3,
When I had version 3.0.0 was fine ..
