Hondata Map Sensor Question
ITR 1102
Post by ITR 1102 »
For lower boost setups such as mine, which Hondata map sensor is the best to use? I like the idea of the presets in the software for the 4 bar sensor, but there are not presets for the 3 bar sensor. I have read about a loss of resolution with the higher the sensor's bar rating, but don't know if that is applicable to the Hondata/Omni Power type sensors. I will have between 12 and 13 psi on the motor. Will there be any advantage to using the 3 bar over the 4 bar?
Re: Hondata Map Sensor Question
There is no advantage and you will not loose any resolution. The 4bar works perfectly.
