h22a model 97-01
mugen715
h22a model 97-01
Post by mugen715 »
hi,
A friend of mine with prelude h22a model 97-01 and stock ecu P5M (OBD2). Do you think his car can be used with ecu hondata s300? Because i checked through your web, it doesn't mention about the ECU P5M
Re: h22a model 97-01
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html . You can then use the Hondata s100 or s300 depending on what options you want ( http://www.hondata.com/sproducts.html ). I would recommend the s300.
