PLX Type B O2 to vx harness
yangeghatch
Post by yangeghatch »
Hey guys, has anyone wire this PLX Type B O2 to the vx harness?
http://www.xenocron.com/plx-type-b-repl ... p-676.html
Goal is to get run wideband on car daily and keep engine bay clean. I already got Apexi AFR meter for the display.
and will it read on the s300 through the harness?
Thanks for the help.
Re: PLX Type B O2 to vx harness
That is just a sensor, you still need the wideband controller from PLX to make it work.
yangeghatch
Cool. I'll look into the controller and hopefully be able to wire the O2 in with the harness and the controller somewhere with the ECU. Thanks.
