Distributor sensors
senjam1
Distributor sensors
Post by senjam1 »
Would relocating the distributor sensors to the crankshaft effect the CPR? Resolution changes would have to be made - maybe using some parts from a k-series if possible.
Re: Distributor sensors
Since we are using a stock ECU, the distributor signals need to be exactly the same as stock. The CPR does not affect this requirement.
