Is it ok to run a s300 pr4 ecu on a 1999 b16a2 honda civic?
wildjames123
Post by wildjames123 »
Hey iv got a pr4 ecu just want to check it's ok to run on my honda civic em1.. its runs the car, just wondering if there are any issues with running this ecu on this car cheers :)
Re: Is it ok to run a s300 pr4 ecu on a 1999 b16a2 honda civ
It is a non-vtec ECU so you will have to use the alternate vtec output and a relay.
http://www.hondata.com/help/smanager/vt ... htsub=vtec
wildjames123
ahhh ok thanks i am slightly confused because vtec works on it?
wildjames123
..? also do you have a link to a guide for wiring in one of your hondata boost controller and a wideband afr?
Thanks for your help..
wildjames123
Spunkster wrote:It is a non-vtec ECU so you will have to use the alternate vtec output and a relay.
Do you know why my vtec would be working because i haven't done this mod?
Maybe someone has modified that ECU.
