check in here! if updating kpro has left you stranded
amorreale24
Post by amorreale24 »
Seems like a lot of people are having issues with kpro and kmanager since the new update. Symptoms include: computer not aknowledging kpro, kmanager saying offline at all times, kmanager not recognizing ignition on, etc.
For a product that is a thousand dollars, and more importantly, is essential to driving your car, it sure has some problems. Every thread started with issues.stated above gets the same response from the admin. " read guidlines blah blah" " you have a wiring issue blah blah". Dozens of people are having the same issue now, the problem is on your end Hondata, and its time we demand a fix. Check in here if you are now having trouble with a kpro that used to work. Maybe they will wake up ad realize its their problem and they should fix it before the situation escalates.
05typeR
Re: check in here! if updating kpro has left you stranded
Post by 05typeR »
i have not bought a Kpro has yet but really looking to buy one very soon. . .will keep my eyes on this post.
amorreale24
As of now I regret buying kpro. Should have gotten the aem unit instead.
There are no known problems with KPros connecting, starting, staying offline or not recognizing ignition on. If you have a problem with your KPro, then I suggest you post the details about what you have and what is not working, as per the guidelines.
Given your lack of previous posts and the tone of your comments, I strongly suspect you have recently found that you have a counterfeit. In that case, go here.
