KPRO III Digital Input
taohawaii
Post by taohawaii »
I GOTTA GET THIS INFO!!!! I recently bought a KPRO III BECAUSE it has a serial input. This means that I can use my own custom controllers (which I play with frequently) to arbitrate all sorts of special sensors and inputs. Not to mention add as many inputs and outputs as I like to my board. I.E. Windows are up, sunroof is closed, stoopid stuff like that. Stupid that is, until you connect the board to the window relay and tell it to roll up the windows when the logged vehicle speed exceeds 55mph (if they are down). Or when I am using KManager as a display console on my carputer and I want to show the status of aftermarket sensors not supported by KPRO.
If I connect my board to the KPRO as an external data logger, then connect my board back to the kpro (say 5V TTL serial 9600,8,1,N,1), can't I change the behavior of my board based on the values "logged" and display the information from my board in the KManager software?
Please, please Hondata give me the API/spec/information required!
Re: KPRO III Digital Input
At the moment the digital input supports input from the AEM, Innovate and PLX widebands (for PLX also all the iM sensors).
