Problem with US R18 ECU on Euro R18 FN1
GuardianSpider
Post by GuardianSpider »
Hi,
I installed an US R18 ECU on my EU R18 car to use the flashpro. (cause it's the only solution to use the flashpro on my car).
So, I've an issue with my car, I've the P0523 DTC error (EOP Sensor) - but my car doesn't have this sensor.
For sure I've a flashpro, do you think you can add the possibility to disable this error with the flashpro or maybe you've another solution to solve my issue.
Actually my car is starting but I'm in "security mode" (limited at 3500rpm)
Thanks in advance (I really need your help)
Michael
Re: Problem with US R18 ECU on Euro R18 FN1
I'm sorry, but it is not recommended or supported to try swapping the ECU into this vehicle to use a FlashPro.
GuardianSpider
Yes for sure, but all is working, the flashpro is connected. I can upload a map, and everything else. So i just need to know if you have a solution to me (like a checkbox to inactivate this sensor) ?
Micka
We do not support ECU swaps.
