Link ECU
blwncr
Link ECU
Post by blwncr »
Hi, im using a Link ECU here in New Zealand in my JDM 98 Accord sir-t. It has a F20b Vtec engine and im running it turbocharged. My question is can i use your CPR with my ecu that uses the factory honda dizzy and ignitor? I ask this question because i have used all the outputs available for other purposes and would like to use a coil on plug setup?
Thanks for any advise given.
Corey
Re: Link ECU
That is a question for Link.
