SManager 1.6.0 (beta)
The main change for this version is to support the CPR without needing to edit ini files, but there are some other minor changes incorporated into the release.
V1.6.0 (2 December 2011)
  • • Added CPR (Coil Pack Retrofit) output to Misc window.
    • Improved datalogging/recording performance when display window is maximized.
    • Fixed tabs in the settings window.
    • Added automatic conversions to sensor display minimum and maximums, and also sensor warning minimums and maximums.
    • Added functionality to saving window position for multiple monitors.
    • Included security check to prevent saving data to Program Files to avoid virtualization problems with Windows.
    • Added Import/Export feature to the Sensor Settings form, the Graph Template form, and main Settings form.
m_sasso
Re: SManager 1.6.0 (beta)
Post by m_sasso »
Thank You!
