how to set tps range with s300
fuel-built
Post by fuel-built »
hi i can not set the tps minimum and maximum readings for s300
when i try to open the read button does not open it why ???
i do not running the engine as hondata says i just turn the key to on position but i can not operate the read button
and how i must set the tps throttle overrun fuel cut off throttle ???
also my car in datalogging at 2000rpm shows 0 tps thanks
Re: how to set tps range with s300
You must have calibration open and be datalogging.
fuel-built
thanks my friend so i must open my calibration and start datalogging and then set the tps range ?then the read button is in operation ?but i am not sure if the s300 can datalog with out start the engine cause hondata says that you must set the tps range with out working the car please help me
Have you tried yet?
fuel-built
no tomorow i try to scale the tps on my itb thanks i wiil tell you then
do you know to program s300?i need some help my friend
fuel-built
yes i try to datalog and at the tps parameters the read button operates but when i push read one time it shows me e.g 0.34 and if i put it again tell me another value if i put it again another ,my tps is godd no problem and the ecu not through any cell light problem with tps when i uplug the tps snd turn the valve with my hand it work fine then the ecu through me out of on line and does not record at dataloging then i stop the car and when i try to start again never start i read your post how to see the s300 problems but my car does not start to see if it upload or if it datalog no start ,i try to run another ecu and the car start ,my ecu does not through any check engine light everything is correct the main relay work the engine light when i start hte car open and close i have spark on my spark plugs i run resistor spark plug i run the last version of smanager i try to set a built in calibration but the car not start please help me i think is the s300 not my ecu ,one tuner told me if i calibrate my car with my laptop at power supply cause it is not good is that the reison you thing and do problem to the s300 ???
B20v_eghatch
Anyone have a basemap for a d16y8 turbo all stock
Post by B20v_eghatch »
97 ek hatch d16y8. Vtec all stock running hondata s300 looking for a basemap
If it is getting a different reading every time then there is either a wiring fault, or a problem with the TPS sensor itself.
