Tuning for better MPG
CL9
Post by CL9 »
How can i tune the cruising for better mpg?
Disable cloose loop and lean the deaired load and rpms?
Or i can set a target afr for cloose loop?
Re: Tuning for better MPG
You can just change the closed loop target lambda and tune the fueling to get as close as you can to that target as well.
CL9
Post by CL9 »
I entered 15.4 as target and 15.7 as limit
Did some logging and leaner it gets is 15.0-14.7
I just keep entering higher values until i reach desired afr?
