Switched gm3bar to stock map sensor Help
burmese434
Post by burmese434 »
When I changed map sensors from a GM 3bar back to a stock map the car starts then dies right out? The only way it will run is if I selected the gm 3bar (Motec) setting? Hondata s300.
I have not installed my wb yet and I was wondering that since I have my wb hooked up to my ecu,that might be the reason? My settings are Scalar 602 and the offset is 2. Let me know what you guys think.
If wondering why I switched back is because built/boosted motors oil pump went out now I'm using a b16a obd0 motor and not to many vacuum spots on the intake.
Also could it be that I have the map sensor wires backwards?. 96 civic cx and if you looking at the map sensor they go Yellow/White*, Red/ Black* Green/yellow maybe Green/White.
Re: Switched gm3bar to stock map sensor Help
Once a MAP sensor is wired incorrectly it damages the sensor and it must be replaced. Check your wiring a then try a different MAP sensor and it should work.
burmese434
Dam lol well can anyone link me to the correct wiring diagram for my 96 civic cx?
