4 egt data logging kpro3
dragoncivic
Post by dragoncivic »
so will i be able to datalog 4 egts at once each cylinder if so wich sensors do you recomend or am i better off to use 4 o2 sensors this is a turbo application with fullrace tubelair manifold setup
Re: 4 egt data logging kpro3
We recommend the PLX widebands or EGT sensor modules. http://www.plxdevices.com/sensors.php
There are 8 inputs so you can use all 8
