S300 with Multi-Coil with AEM EPM, is how?
HeitorVTiBR
Post by HeitorVTiBR »
Ola .. is possible using multi-coil using the AEM EPM with hondata S300, OBD1?
Re: S300 with Multi-Coil with AEM EPM, is how?
The s300 does not change the Honda ECU hardware, so the answer this question is 'does the AEM EPM work with a stock Honda ECU?'
HeitorVTiBR
I know, is that the AEM EPM will spot the original distributor, serving only to capture the signal of the motor position ...
I want to remove the distributor and use four coils, one per cylinder .. is it possible?
surfingsk8r
Post by surfingsk8r »
Hondata CPR, I hear that it works great.
HeitorVTiBR
surfingsk8r wrote:Hondata CPR, I hear that it works great.
But four coils is used? or only a distributor with one coil?
