07 RDX reflash question
mstolars
Post by mstolars »
Hi, I'm interested in getting the hondata reflash for my 2007 RDX and I would like to know if I could send in an ECM purchased from a wrecked RDX and have it reflashed and use it in my RDX? I got the ECM cheap and figured it would be a good idea to keep the stock ECM so I won't have downtime when sending it to hondata. Thanks for any help.
Re: 07 RDX reflash question
Make sure that the ECU part number is exactly the same as your current ECU. You will need to go to the Acura dealer and get your immobilizer matched to your ECU - note that once this is done the stock ECU will not work until the immobilizer is re-matched back to it.
Also the Vin will not match.
