Can't see my AFR lambda in fuel tables..plx wideband install
tb144050
Post by tb144050 »
I must be overlooking something or forgetting to uncheck a box somewhere.
I just installed my plx wideband setup. My dm-6 gauge is working but I can't see the value in hondata.... I am at the step where I am supposed to "offset voltage until hondata value (14.7, for example) matches the dm-6 gauge. However, I open hondata, download my basemap from the ecu, click the fuel table, and then click "view...lambda", but my table is empty. :(
I have made sure that I have cut d14 and connected to the ecu side of the cut. Then I made sure that hondata will look for d14 ELD input for wideband. My narrowband is wired to d10. Within the hondata software, my afr digital gauge responds to gas pedal (fluctuates consistently between rich and lean....yes its untuned...).....so I know hondata is receiving some kind of input, narrow or wide, but I just cant make it show up in the lambda tables.
What am I forgetting??
--TJ
I have tried open and closed loop, but the table stays empty.
Yes, i am a noob. I bet you were a noob once upon a time. lol
Re: Can't see my AFR lambda in fuel tables..plx wideband ins
In Settings, Sensor Overlay, make sure all the minimum and maximum values are correct.
Sesso
Post by Sesso »
Use the D10 as your wideband and D14 for the narrowband. Then in the closed loop section at the bottom, make sure it says D10.
Then my lambda table is set like this.
0.00 2.35 5.00
10.00 14.70 20.00
tb144050
Post by tb144050 »
Thanks for the help. I can't wait to check it out tomorrow afternoon.
