Bad clutch switch???
Dusty
Post by Dusty »
I recently bought and installed my s200 with the 3 step and full throttle shift and had my car tunned, however i am wondering if the switch is bad because the lauch control activates at a rest with clutch in or clutch out and at all other times, reguardless of clutch movement, the rev-limited is at 6500, now when i unplug the control from the box my revlimiter is at its normal position, I also check the switch to see make sure it was making proper contact with the pedel arm, and although it was, adjusted to see if that was perhaps the problem, I have also flipped the wires on the switch which also made no differnence, has anyone else had the problem and if you guys think its a bad switch, what would be the best way to go about returning it, thanks!
Edit: not sure it matters but this unit is on a p28 running b20 vtec in a rex
USe a multimeter to check continuity of the clutch switch to make sure it switching off an on.
