Feature Request: IAT Sensor Scalar
The Spectacle
Post by The Spectacle »
I'm interested in converting the OEM IAT sensor to a faster sensor, GM style sensor and adding a PLX IAT sensor pre intercooler to measure the intercoolers efficiency within the datalogs. I'm being told that using anything other than the OEM sensor will not be accurate due to the lack of an IAT sensor scalar conversion table to modify how the temperature is calculated by the ECU. Converting to a different sensor with inaccurate readings would negate my reason for changing it in the first place. Is it possible to add scalar tables to the IAT similar to the MAP sensor?
The Spectacle
Re: Feature Request: IAT Sensor Scalar
Hondata?
TTR
Post by TTR »
Why do you need a "faster" IAT?
The Spectacle
Boost applications
TTR
Post by TTR »
So you think the Honda sensor doesn't respond fast enough?
The Spectacle
yes. its been proven.
TTR
Post by TTR »
I've used GM sensors on other systems and have never noticed it being faster. You sure its not the sample rate of the software?
The Spectacle
TTR wrote:I've used GM sensors on other systems and have never noticed it being faster. You sure its not the sample rate of the software?
yes
