Kmanager Version 3
its_ish
Kmanager Version 3
Post by its_ish »
Hi, I have purchased a Kpro Version 3 and installed the new K manager into my laptop. I was trying to open/upload an older dyno tune map/kal to the new Kpro, but each time I try to open the kal file nothing happens. This only happens on my older map/kal files, new maps work. Can you please shed some light to this problem asap? I need to get my race car up and running (I share Kpro between 3 cars).
Re: Kmanager Version 3
Make sure you have KManager 3.0.3 or later.
If the calibration will not load then email it to support@hondata.com. The usual cause is that an EPROM binary has been saved with a .kal file extension. A file size of 32768 bytes indicates this.
its_ish
Post by its_ish »
I have the version 3.0.3 supplies with the Kpro version 3.
Arent all calibrations saved as a .kal file?
Anyways, the file size is 208 KB (213,888 bytes). I have emailed the file for your perusal.
We dont' know what this file is, but it's not a calibration file.
its_ish
Post by its_ish »
Huh? all of our Kpro calibration maps new and old range between 150 KB to 220 KB. Am I missing something here? Ive emailed you the file, please check and advise.
The calibration files are text files. Open one up in notepad and you'll see what the problem is.
