FLashPro request for Euro CL9
peter.d
Post by peter.d »
Hi,
I have a 2007 Euro CL9 , k24a3, M/T with ECU part number : 37820-RBB-E05
Will you please release a FlashPro for this, too ?
I know there are a few CL9 in Europe which runs with Hondata ECU reflashed by you without any issues ( no check engines )
so I believe a FlashPro for this could be possible, too.
Thanks,
Peter
Zoro2006
Re: FLashPro request for Euro CL9
Post by Zoro2006 »
peter.d wrote:Hi,
Thanks,
Peter
it's not possible to use FlashPro with this ECU, buy ECU from TSX 07-08 and buy FlashPro kit for TSX 04-06
Known as Vaikis_
peter.d
Post by peter.d »
that will be pointless, a lot of money for very small gain, nobody wants to buy another ECU to use this
we want flashpro to work with our ECU as they made it work for other EU cars (FN2, S2k,...)
this is the request for
Zoro2006
Post by Zoro2006 »
peter.d wrote:that will be pointless, a lot of money for very small gain, nobody wants to buy another ECU to use this
it's not posssibe, ECU in your car is almost the same as in TSX 06
Buy ECU from TSX 07-08 and don't waist your time asking FlashPro for CL9 ECU.
P.S. It's possibe to buy used TSX ecu, just search.
Known as Vaikis_
Swapping of ECUs is not recommended or supported by Hondata for this.
core58
Post by core58 »
you may consider using a simple Reflash instead with your CL9.
You can benefit huge gains from FlashPro only if you have heavy hardware modifications or you're planning to have.
Otherwise, you're right, thats much money for a gain of a Reflash equivalent.
P.S. reflashed ECU works just fine with Euro CL9, instead of official Hondata replies :D
dinoc
Post by dinoc »
[to be deleted]
peter.d
Post by peter.d »
that will be the second choice if Hondata won't bother to release something for EU
Zoro2006
Post by Zoro2006 »
peter.d wrote:that will be the second choice if Hondata won't bother to release something for EU
even TSX 04-06 stock ECU can't work with FlashPro and you expecting that Hondata makes one for CL9 Euro when even they don't have such car here in USA. Stop dreaming, want solution - buy same FlahsPro as for TSX 04-06 and use ECU from TSX 07-08. All works, Hondata even made changes in FlashPro manager and we can disable EVAP errors in our CL9 Euro cars, so no more any "check engine" lights in dash.
Known as Vaikis_
peter.d
Post by peter.d »
they made a Flashpro for FN2 (which is not sold in US) and for the Euro s2k which , again, is not sold in US
Zoro2006
Post by Zoro2006 »
peter.d wrote:they made a Flashpro for FN2 (which is not sold in US) and for the Euro s2k which , again, is not sold in US
Don't waist a time if you want a FlashPro, just get TSX 07-08 ECU as all other TSX 04-06 owners must do. It's working solution for Euro CL9.
Known as Vaikis_
peter.d
Post by peter.d »
Mate that's just too much for what I need ( an exhaust and an intake) , the cost for another ECU + the cost for FlashPro is way too much.
