Which pinout from ecu ?
redturbos2k
Post by redturbos2k »
Hello guys.
My car is 07 european s2000 so I'm using Flashpro and Innovate MTX-L series wideband.And It has two analog outputs.
I'm planning to connect my ecu to wideband for closed and open loop operation.But I dont know excatly Which pin should I use for connection on ecu.Does anyone tell me ? Thanks
Re: Which pinout from ecu ?
Use ECT2 (pin E1).
You can only run in closed loop using the factory wideband. It will not run in closed loop with a aftermarket wideband input.
redturbos2k
Should I disable second ect sensor on Flash pro ? And Sould I splice or cut cable for connection ?
redturbos2k
Spunkster wrote:You can only run in closed loop using the factory wideband. It will not run in closed loop with a aftermarket wideband input.
So I have to use first oxygen sensor for it ? Am I right ?
