s 300 problem
k20brasil
s 300 problem
Post by k20brasil »
Hi, already use the S300 to 3 months without any problem, but today morning the car stopped working,datalog does not work, and when you download this message appears: CLASS T GROUP NOT FOUND, and car is not running, and and (display) datalog is frozen.
Re: s 300 problem
Download the latest version of SManager from http://www.hondata.com/downloads.html
k20brasil
Re: s 300 problem
Post by k20brasil »
Ok download ver. 2.0.0 and car is runing good!, but after 40 secs. after start, s300 blink red ligth and blink cel ligth and car shut off, car runing if.....the car only works if I give erase the ECU and then down the map without turning off the ignition, the car runs for 40 secs and die...... if I turn the ignition off and on again, the light is already red from the S300 and the car does not datalog and not start the engine, the engine works only if I erase the ecu again, download the map and start the engine without turning off the ignition! engine runing perfect.
Re: s 300 problem
What is the serial number of the s300?
k20brasil
Re: s 300 problem
Post by k20brasil »
sn: #s300-12,405
Re: s 300 problem
Send an email with a link to this thread to support <at> hondata.com.
Include the following:
Name:
Address:
Phone:
Email:
Serial#:
