CEL even after kpro?
MarkyMark203
Post by MarkyMark203 »
I just picked up my kpro last night and was having a blast playing with it, Hondata FTW with this one! Stupid easy!
Setup: K20z3 in 97 EK I/H/E 11.7:1 STOCK HEAD
Anyway, previously before the kpro I was running on a JDM PRD ECU, & the only two codes I would get when jumping the blue plug on passenger side were:
(39) - Multiplexer
(65) - Secondary Oxygen Sensor
A friend of mine had his ITR EK tuned by Evan's Tuning and he sent me the .kal file to use for my setup since it was rather close I thought. Upon uploading and starting the car I still had a CEL, but no hard codes in KPRO. Didnt know what was causing it so I tried a regular A2 basemap from KMANAGER. I then went to parameters and disabled the OBD2 function, disabled the IACV since Im not using it, and disabled Secondary Oxygen Sensor. Started the car again and still had the CEL on, but this time I had two hard codes in KMANAGER. They were:
(?????) - VTEC Malfunction
(p0134) - Secondary Oxygen Sensor
Im no wiz with kpro but everything was a breeze. Am I missing something here?
IVE ATTATCHED MY .KAL FILE TO SEE IF SOMEONE CAN PLEASE HELP, IM HITTING STREET WARS TOMORROW @ ETOWN
Re: CEL even after kpro?
Do you have a secondary o2 sensor? What is the other error code you are getting? Have you tried datalogging using the software?
MarkyMark203
Actually got this solved. Secondary was still enabled in closed loop.
Thanks for your response.
