For any/all who are interested, now and in the future:
What will happen if you run the exact same setup but with higher compression? Run richer, leaner, etc??
For example, I am running a h22 setup but I am switching out my crank and rods for f22 crank and rods bc they have longer stoke and that = higher compression. All the rest of my setup will remain the same.
I will post my experience when I get all this back from the shop and thrown back together, However, I am scared about what will happen when I first crank it up...do I need to make ANY kind of adjustment to keep it from blowing up on the first turn-over?
--TJ
What effects will longer stroke/raising compression have?
Yes, i am a noob. I bet you were a noob once upon a time. lol
Re: What effects will longer stroke/raising compression have
It will run leaner, definitely. Maybe richer on the low end.
And personally, ive always been more of a fan of milling the head or decking the block, but to each their own.
02 RSX Type S (sold)
11 TSX Tech (daily)
Hit me up for free Hondata Help. Over 4K downloads on my famous GSR Tune!
11 TSX Tech (daily)
My "H" needed new rings, but then it spun a bearing. So while tearing down for the new bearing, I decided to tear down further for new rings. Since I was already that far, I decided to put in my "F" crank and rods for the heck of it.keto06 wrote:It will run leaner, definitely. Maybe richer on the low end.
I could also mill/deck if I wanna raise compression even more..hehe
--TJ
