immoblizer light/ fuel prime problem
kgpmotorsport
Post by kgpmotorsport »
hi,
i have an ep3 uk spec, with kpro fitted, which wont start the car. The immoblizer is disabled in the map, but the dash board light still flashes for it.
Also the fuel pump wont prime when the ignition is switched on, but the relay seems to be clicking on ok.
any help appreciated.
kevin
Re: immoblizer light/ fuel prime problem
What is the serial number of the K-Pro board inside the ECU and what is the serial number of hte ECU on the outside of the case? From Help, About, what version of software are you using?
